[gdal-dev] gdal_edit.py -a_nodata none
Even Rouault even.rouault at mines-paris.org
Fri Aug 23 06:23:22 PDT 2013
Selon peifer <peifer at gmx.eu>:
> Hi,
> http://www.gdal.org/gdal_edit.html states about -a_nodata
> > Assign a specified nodata value to output bands.
> > Can be set to none to remove a nodata value if one exists for the dataset.
> I assume that none means the literal string `none', but what happens is
> given below.
> Is this just a plain bug or am I doing something terribly wrong?
Hi Hermann,
This is a documentation bug. This is not supported by the code. And there's no
(standard) way in the GDAL API to remove a nodata value once it is set.
Could you file a ticket about that ?
Even
