[gdal-dev] convert UTM 2 Latlong
Murat Beyhan muratbeyhan28 at gmail.com
Sat Aug 24 13:13:37 PDT 2013
I have tried to do before but until I can't succeded please help me
how to convert utm data into geographic lat/lon data.
I have point and line data in shape file and I would like to convert it
into lat/long data
I thing this could be done using gdaltransform but I dont know how to do. I
have need your help urgently.
regards.
Murat
My data as follows
  gdalinfo g23d4_gh.tif
Driver: GTiff/GeoTIFF
Files: g23d4_gh.tif
Size is 200, 200
Coordinate System is:
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.257223563,
            AUTHORITY["EPSG","7030"]],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0],
    UNIT["degree",0.0174532925199433],
    AUTHORITY["EPSG","4326"]]
Origin = (711464.640000000013970,4486337.679999999701977)
Pixel Size = (54.924799999999813,70.906000000000930)
Metadata:
  AREA_OR_POINT=Area
Image Structure Metadata:
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (  711464.640, 4486337.680) (Invalid angle,Invalid angle)
Lower Left  (  711464.640, 4500518.880) (Invalid angle,Invalid angle)
Upper Right (  722449.600, 4486337.680) (Invalid angle,Invalid angle)
Lower Right (  722449.600, 4500518.880) (Invalid angle,Invalid angle)
Center      (  716957.120, 4493428.280) (Invalid angle,Invalid angle)
Band 1 Block=200x40 Type=Byte, ColorInterp=Gray
  NoData Value=0
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130824/77082f4b/attachment.html>
