[gdal-dev] Geotransform - rotation and translation
Oyvind Idland oyvind.idland at gmail.com
Tue Aug 27 00:05:31 PDT 2013
That won't work, since it will move the corner point half a cell, and then
rotate around the new corner.
- Øyvind
On Mon, Aug 26, 2013 at 7:02 PM, Norman Vine <nhv at cape.com> wrote:
> On Aug 26, 2013, at 12:50 PM, Oyvind Idland <oyvind.idland at gmail.com>
> wrote:
> I am currently working on a driver for a proprietary format, which is
> being consumed by ArcGis via GDAL.
> These grids sometimes has a rotation with a specified pivot point. I
> managed to get ArcGis to display the rotated grid by doing the following:
> poDS->dGeoTransform[0] = originX;
> poDS->dGeoTransform[1] = cos(rotation) * cellSizeX;
> poDS->dGeoTransform[2] = -sin(rotation) * cellSizeX;
> poDS->dGeoTransform[3] = originY;
> poDS->dGeoTransform[4] = sin(rotation) * cellSizeY;
> poDS->dGeoTransform[5] = cos(rotation) * cellSizeY;
> Rotation is in radians. It works, but there is one problem: I need to
> rotate the grid around the center of the corner cell (originX, originY),
> but ends up getting rotation around the corner of the cell/raster instead.
> There is a screenshot here, showing only the corner pixel. The topmost
> grid/pixel was translated using custom geotransform in ArcGis, the bottom
> one is the result of my GDAL rotation:
> The cyan dot shows the pivot point:
> http://i.stack.imgur.com/7HEvc.png
> Is there any way to express this translation using the geotransform matrix
> I think this should work
> poDS->dGeoTransform[0] = originX + cellSizeX/2.0;
> poDS->dGeoTransform[3] = originY - cellSizeY/2.0;
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130827/c1778d80/attachment.html>
