[gdal-dev] Accessing ArcGIS Rest service troubles
Pavel Iacovlev iacovlev.pavel at gmail.com
Tue Aug 27 02:19:57 PDT 2013
Hello,
I get a segmentation fault when I try to access data from an ArcGIS
Rest service:
OS: Ubuntu 12.04
GDAL: GDAL 1.9.2, released 2012/10/08
GDB:
Starting program: /usr/bin/gdalinfo
"http://geoportal.ancpi.ro/cachegis/rest/services/ImobileStereoPublic/MapServer?f=json&pretty=true"
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff73d4c50 in std::vector<std::string,
std::allocator<std::string> >::~vector() () from /usr/lib/libgdal.so.1
I tried on a different machine where I have a newer GDAL, here it's
just a unsupported format error
OS: Ubuntu 10.04
GDAL: GDAL 1.10.0, released 2013/04/24
ERROR 4: `/vsimem/http_1/file.dat' not recognised as a supported file format.
ERROR 4: `/tmp/file.dat' not recognised as a supported file format.
gdalinfo failed - unable to open
'http://geoportal.ancpi.ro/cachegis/rest/services/ImobileStereoPublic/MapServer?f=json&pretty=true'.
Any ideas whats wrong ?
Best Regards
Iacovlev Pavel
