[gdal-dev] problems with compilation in vs2012
Tamas Szekeres szekerest at gmail.com
Tue Aug 27 08:57:13 PDT 2013
Darrel,
Looks like the winsock library should also be included as an input for the
linker of your app. (ie. wsock32.lib).
Best regards,
Tamas
2013/8/27 Darrel Maddy <darrel.maddy at newcastle.ac.uk>
>  Hi all,****
> I’m not entirely sure what I can do next. ****
> We use gdal to input and output grids from our Landscape Evolution Model.
> Everything is working fine under linux but we are trying to develop
> cross-platform.****
> I downloaded the gdal-1.10.0 zip and altered the #win64 element of the
> options file and compiled using nmake –f makefile.vc MSCV_VER=1700 after
> running the vcvarsall.bat for amd64 . The library looks fine.****
> I have all the project properties setup to see the source directories
> (includes : default, plus gcore and port) and the linker is shown the way
> to the gdal.lib file.  Despite knowing where the library is I am getting
> the following linker errors****
> 1>     Creating library E:\vs2012 projects\iwaveVS\x64\Release\iwaveVS.lib
> and object E:\vs2012 projects\iwaveVS\x64\Release\iwaveVS.exp****
> 1>gdal.lib(gdalclientserver.obj) : error LNK2001: unresolved external
> symbol __imp_closesocket****
> symbol __imp_connect****
> symbol __imp_recv****
> symbol __imp_send****
> symbol __imp_socket****
> symbol __imp_WSAStartup****
> symbol __imp_WSACleanup****
> symbol __imp_getaddrinfo****
> symbol __imp_freeaddrinfo****
> 1>E:\vs2012 projects\iwaveVS\x64\Release\iwaveVS.exe : fatal error
> LNK1120: 9 unresolved externals****
> 1>****
> 1>Build FAILED.****
> I have done this many times against earlier gdal libraries using VS2010
> and not had this problem ( note I did however, in desperation compile
> against VER=1600 and set the toolset in VS2012 to 2010 but that had the
> same issue).****
> What am I missing?****
> Apologies if this is a stupid question.****
> Darrel****
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130827/c3c08eb4/attachment.html>
