[gdal-dev] Patch for GDAL Web Mercator Issue / trac 3962
Stefano Iacovella stefano.iacovella at gmail.com
Thu Aug 29 14:05:44 PDT 2013
2013/8/29 Even Rouault <even.rouault at mines-paris.org>
> My main question is : how sure are we about the projection name
> "Mercator_Auxiliary_Sphere" to be the appropriate one for "standard" WKT ?
> Is
> there some reference from that ? The fact that ESRI uses it doesn't make it
> necesserarily a standard (although it can serve as a base if there's no
> alternative).
According to http://epsg-registry.org/, not an ISO standard but quite a de
facto standard, EPSG:3857 is "WGS 84 / Pseudo-Mercator "
Kind Regards,
Stefano
41.95581N 12.52854E
http://www.linkedin.com/in/stefanoiacovella
http://twitter.com/#!/Iacovellas
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130829/155dbf4b/attachment.html>
