[gdal-dev] GDAL for windows
Tamas Szekeres szekerest at gmail.com
Fri Aug 30 01:41:03 PDT 2013
Not sure what you mean by "MapServer for Windows was built in May 2012",
the daily build packages should contain the latest versions of the
development and stable branches.
Your issue may probably be related to the OSM driver specifically. How is
your ogr2ogr command line looking like?
Best regards,
Tamas
2013/8/30 <nicholas.g.lawrence at tmr.qld.gov.au>
> Hello all,
> I would like to install the latest GDAL for windows (32-bit). But I can't
> find a binary install that works.
> My goal is to translate an OSM .pbf file into MapInfo TAB. For this I need
> the latest OGR2OGR
> I tried the download from www.gisinternals.com/sdk/ but that gives me the
> error "Layer lines not found, and CreateLayer not supported by driver."
> MapServer for Windows was built in May 2012, so it wouldn't include the
> OSM read ability
> OSGeo4W is an installer that has to connect to the internet, and my
> firewall blocks the connection, so I can't use that.
> FWTools does not have the latest GDAL version, which I need
> Kind regards,
> Nick Lawrence*
> Senior Spatial Science Officer | Geospatial, Road Design & Competency
> *Engineering & Technology Branch* | Department of Transport and Main Roads
> Floor 19 | Brisbane City - 313 Adelaide Street | 313 Adelaide Street |
> Brisbane City Qld 4000
> GPO Box 1412 | Brisbane City Qld 4001
> P: (07) 30667977 | F: (07) 30668998
> E: *nicholas.g.lawrence at tmr.qld.gov.au*<nicholas.g.lawrence at tmr.qld.gov.au>
> W: *www.tmr.qld.gov.au* <http://www.tmr.qld.gov.au/>
> WARNING: This email (including any attachments) may contain legally
> privileged, confidential or private information and may be protected by
> copyright. You may only use it if you are the person(s) it was
> intended to be sent to and if you use it in an authorised way. No one
> is allowed to use, review, alter, transmit, disclose, distribute, print
> or copy this email without appropriate authority.
> If this email was not intended for you and was sent to you by mistake,
> please telephone or email me immediately, destroy any hardcopies of
> this email and delete it and any copies of it from your computer
> system. Any right which the sender may have under copyright law, and
> any legal privilege and confidentiality attached to this email is not
> waived or destroyed by that mistake.
> It is your responsibility to ensure that this email does not contain
> and is not affected by computer viruses, defects or interference by
> third parties or replication problems (including incompatibility with
> your computer system).
> Opinions contained in this email do not necessarily reflect the
> opinions of the Department of Transport and Main Roads,
> or endorsed organisations utilising the same infrastructure.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130830/e54c060f/attachment.html>
