[gdal-dev] GDAL python tools and batch files
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Mon Dec 2 04:13:48 PST 2013
Thanks Paul, that did it. I guess it's a python/batch file interaction
thing.
Cheers,
Jonathan
On 2 December 2013 11:51, Paul Meems <p.meems at topx-group.nl> wrote:
> I think you should add 'call' at the begining of the command:
> http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/call.mspx?mfr=true
> Met vriendelijke groet,
> Paul Meems
> *Paul Meems*Senior GIS consultant
> 06-53989481
> TopX Geo-ICT <http://www.topx-geo-ict.nl>
>  <http://topx-group.nl/topx-geo-ict>Wij bieden ondersteuning
> voor MapWindow GIS <http://www.mapwindow.org/>
> 2013/12/2 Jonathan Moules <jonathanmoules at warwickshire.gov.uk>
>>  Hi List,
>> I'm trying to batch (Windows) a fairly simple task - mosaic and then
>> pyramid some rasters.
>> While testing, I've simplified my batch file down to two lines:
>> gdal_merge -o %THIS_DIR%.tif -of GTiff -co TILED=YES -co BIGTIFF=YES -co
>>> COMPRESS=JPEG -co JPEG_QUALITY=80 -co BLOCKXSIZE=512 -co BLOCKYSIZE=512
>>> --optfile tiff_list.txt -co
>>> PHOTOMETRIC=YCBCR
>>> pause
>> The problem is that once gdal_merge has finished processing, rather than
>> continue onward the batch file ends, so in this case the "pause" is never
>> triggered. Doesn't matter what comes next, the batch ends as soon as the
>> merge is complete.
>> However the same simple batch file but with a gdaladdo command instead
>> works fine. Is this a python thing?
>> Anyone know why that is? Should it be doing this? Using the OSGeo GDAL
>> 1.10.1 build, but it happened with FWTools too (thought it was a FWTools
>> bug at the time).
>> Tested on Windows 7 and Server 2008.
>> Cheers,
>> Jonathan
>> This transmission is intended for the named addressee(s) only and may
>> contain sensitive or protectively marked material up to RESTRICTED and
>> should be handled accordingly. Unless you are the named addressee (or
>> authorised to receive it for the addressee) you may not copy or use it, or
>> disclose it to anyone else. If you have received this transmission in error
>> please notify the sender immediately. All email traffic sent to or from us,
>> including without limitation all GCSX traffic, may be subject to recording
>> and/or monitoring in accordance with relevant legislation.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131202/2c0fc39a/attachment-0001.html>
