[gdal-dev] GetFeature() and attribute/spatial filters
Even Rouault even.rouault at mines-paris.org
Mon Dec 2 11:34:03 PST 2013
Frank noticed in http://trac.osgeo.org/gdal/ticket/5309 that the generic
implementation of GetFeature(), which uses GetNextFeature() internally, did
not respect its documented behaviour. It should have ignored any attribute or
spatial filter, which it didn't up to
http://trac.osgeo.org/gdal/changeset/26688. Now it will temporarily drop any
attribute or spatial filter during the GetFeature() call, and restore it back
afterwards (caution: the sequential pointer of GetNextFeature() will have been
modified, as before)
Authors of drivers that override SetAttributeFilter() and/or
SetSpatialFilter() and/or GetFeature() must have in mind that assumption.
I've upgraded the OGDI, PG, MySQL, MSSQLSpatial, OCI, SDE, PGeo, ODBC, WALK,
IDB, SQLite and Ingres drivers. Hopefully no other driver update is needed,
but you are kindly welcome to check.
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
