[gdal-dev] Generating Lat, long Cordinates with bearing line and angle
Phil Scadden p.scadden at gns.cri.nz
Mon Dec 16 12:49:23 PST 2013
> I have a *lat, lon* coordinate with a known projection system I assume
> it a initial point. I want to generate a next Position with the an
> *angle* with (horizontal/vertical)  and *bearing length*  in lat,lon
> coordinates and complete it with angles and bearing lengths to form a
> polygon
Try http://www.movable-type.co.uk/scripts/latlong.html#destPoint
However, you need to be very careful with this as calculations are being
done assuming a spherical earth. Fine is distances arent large enough
for the ellipsoidal effects to affect accuracy. For large distances, you
need to use Vincent' s_formula -
http://en.wikipedia.org/wiki/Vincenty%27s_formulae which require iteration.
Notice: This email and any attachments are confidential.
If received in error please destroy and immediately notify us.
Do not copy or disclose the contents.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131217/6611bd11/attachment.html>
