[gdal-dev] ISO WKB
Even Rouault even.rouault at mines-paris.org
Tue Dec 17 12:32:23 PST 2013
Le mardi 17 décembre 2013 21:16:25, Dmitriy Baryshnikov a écrit :
> Hi,
> I afraid that we come to situation where:
> getGeometryType()
> getIsoGeometryType()
> getRFCGeometryType()
> getBlahBlahGeometryType()
> Why not have only one method and only one enum (as GDAL origin - single
> abstract data model to the calling application for all supported formats).
> I think all ISO specific things should be internal and driver specific.
> So, we will get single GDAL enum of geom types.
I don't see it a problem if we have different getXXXGeometryType() or
exportToXXXX() methods in OGRGeometry, provided that they document well the
standard/document they implement. The ISO WKB encoding is a standard, so it
can be a legitimate interface of OGRGeometry, and could potentially be used in
several drivers ( actually if you look at OGRSpatialReference class it has a
lot of import / export methods to various exotic formats, only used by one
driver ).
> Best regards,
>      Dmitry
> 17.12.2013 18:09, Mateusz Loskot пишет:
> > On 17 December 2013 09:03, Even Rouault <even.rouault at mines-paris.org>
wrote:
> >> Selon Paul Ramsey <pramsey at cleverelephant.ca>:
> >>> Back to this, is it OK?
> >> As said in
> >> http://lists.osgeo.org/pipermail/gdal-dev/2013-December/037738.html, I
> >> feel a bit unconfortable with the extension of the OGRwkbGeometryType
> >> enumeration that has possible impacts on other parts of OGR. There's
> >> perhaps a time where we will touch it, but I'd expect it to ideally
> >> embrace Z, M, ZM, circular geometries at once. And that would deserve a
> >> RFC.
> >> What do you think of keeping it an internal enumeration of OGR, since
> >> that's probably all you need for now ?
> >> "Or have a separate OGRwkbIsoGeometryType enumeration { wkbPointIso, ...
> >> wkbGeometryCollectionIso, wkbPointIsoZ, ... wkbGeometryCollectionIsoZ },
> >> a getIsoGeometryType() method that returns it, and the exportToWkb()
> >> methods that calls int getGeometryType(OGRwkbVariant eVariant) { return
> >> (eVariant == wkbVariantOgc) ? getGeometryType()  :
> >> getIsoGeometryType(); }"
> >> I'd be happy to hear about other GDAL developers opinion on this.
> > IMHO, each format based on a particular spec/standard should be
> > supported with a separate interface (enum + functions)
> > per format/standard.
> > Best regards,
Geospatial professional services
http://even.rouault.free.fr/services.html
