[gdal-dev] Python ogr DataSource.ExecuteSQL syntax?
    David Verbyla
    dlverbyla at alaska.edu
    Mon Feb  4 19:32:11 PST 2013
I am trying to figure out the syntax for .ExecuteSQL using Python ogr.
For example:
fireLayer.SetAttributeFilter(None) #returns all 2623 polygons
fireLayer.SetAttributeFilter(" FIREID < 75 ") #returns 4 polygons
I am trying to get the same results using the ExecuteSQL:
testLayer = dataSource.ExecuteSQL("select * from fireLayer")
type(testLayer) #retuns NoneType
testLayer = dataSource.ExecuteSQL("select * from fireLayer where FIREID <
75")
Thanks in advance.
Dave Verbyla
On Sat, Dec 22, 2012 at 7:17 AM, David Verbyla <dlverbyla at alaska.edu> wrote:
> I am a newbie to OGR/OSR using Python 2.7.2, please excuse my ignorance:
>> I am trying to find the distance to the closest polygon for each point.
>> Is there a more efficient way than simply computing the distance to all
>> polygons for each point?  For example:
> nPts = pointsLayer.GetFeatureCount()
> nPolys = polysLayer.GetFeatureCount()
> for pt in range(0,nPts):
>       minDist = 1000000
>       pointFeature = pointsLayer.GetFeature(pt)
>       for poly in range(0,nPolys):
>             polyFeature = polysLayer.GetFeature(poly)
>             Dist = pointFeature.GetGeometryRef().Distance(
> polyFeature.GetGeometryRef() )
>             if (Dist < minDist):
>                   minDist = Dist
>       print (pt,minDist)
> Thank you.
> Dave Verbyla
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130204/52f1ac05/attachment.html>
