[gdal-dev] orginfo unable to open GPX file
Even Rouault even.rouault at mines-paris.org
Tue Feb 5 02:13:38 PST 2013
> What could be wrong? What to look for? How to solve this problem?
If you look at the file with a text editor, does it look like a XML file with a
<gpx> element ? If so, you can open a ticket in GDAL Trac with the file attached
for investigation.
> Brett
> Brett Walker
> <brett.walker at geometryit.com<mailto:brett.walker at geometryit.com>>
> Software Developer / Analyst
> Geometry Pty Ltd
> Telephone               03 6223 1999
> Mobile                     0458 498 386
> Fax                          03 6223 1988
> Web                        www.geometryit.com<http://www.geometryit.com/>
> Address                   31 Salamanca Square, Battery Point, TAS 7004,
> Australia
