[gdal-dev] GDAL RPC protocol to make GDAL (more) failsafe
David Shean dshean at uw.edu
Tue Feb 5 17:00:57 PST 2013
Even,
This sounds great.  I'm guessing RPC in this context stands for "Remote Procedure Call."  It seems like this could potentially lead to some confusion with existing GDAL functionality (e.g., gdal_rpc.cpp) and options (e.g. RPC_DEM) where RPC stands for "Rational Polynomial Coefficients" used during warping/orthorectification.  I suppose that as long as the documentation is clear, this won't be a major issue.  Just thought I'd mention it.
-David
On Feb 5, 2013, at 3:55 PM, Even Rouault wrote:
> Hi,
> Just to inform you that I've just commited in trunk a new feature.
> See http://trac.osgeo.org/gdal/ticket/4979 :
> When dealing with some file formats, particularly the drivers relying on third-
> party (potentially closed-source) libraries, it is difficult to ensure that
> those third-party libraries will be robust to hostile/corrupted datasource.
> The implemented solution is to have a fake driver that will expose a
> GDALClientDataset object that will forward all the API calls to another
> process ("server") where the real driver will be run. This way, if the server
> segfaults, the calling process will be unaffected and will report a clean error
> instead of segfaulting itself.
> This is controlled by setting the GDAL_RPC config option to YES. The option can
> also be set to a list of file extensions that must be the only ones to trigger
> this mechanism (e.g. GDAL_RPC=ecw,sid)
> For now, the server launched is the gdalserver executable on Windows. On Unix,
> the default behaviour is to just fork() the current process (the gdalserver
> executable can also be execvp()'ed by forcing GDAL_RPC_SERVER=YES).
> To avoid the cost of forking()/CreateProcess(), a pool of connections is used.
> This is controlled with the GDAL_RPC_RECYCLE config option that is set to YES
> by default.
> Note: the client/server approach can also be used for thread unsafe drivers
> (not actually tested).
> Demo with a corrupted ECW file :
> Normal GDAL run :
> $ gdalinfo corrupted.ecw -checksum
> Driver: ECW/ERDAS Compressed Wavelets (SDK 3.x)
> Files: corrupted.ecw
> Size is 128, 128
> Coordinate System is:
> [ ... snip ... ]
> Band 1 Block=256x256 Type=Byte, ColorInterp=Gray
> Segmentation fault
> Under the RPC mechanism :
> $ gdalinfo corrupted.ecw -checksum --config GDAL_RPC YES
> Size is 128, 128
> [ ... snip ... ]
> ERROR 1: Read from pipe failed
> ERROR 3: Checksum value couldn't be computed due to I/O read error.
>  Checksum=0
>  Mask Flags:
>  Offset: 0,   Scale:0
> Of course, there's a small performance cost associated to the RPC round-trips.
> Best regards,
> Even
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
