[gdal-dev] Issue with GDAL WCS 1.1.x request
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Fri Feb 8 09:25:44 PST 2013
Robert Kulawik <rob-news <at> gmx.de> writes:
> Hi List,
> i try to request my Geoserver WCS (GS version 2.2.x, request 1.1.x) with
> GDAL 1.9.1.
> Here is the coverage description from Geoserver:
http://193.175.162.189/geoserver/wcs?request=DescribeCoverage&identifiers=raster_example_20130208_113005_078&VERSION=1.1.0
http://193.175.162.189/geoserver/wcs?request=DescribeCoverage&identifiers=raster_example_20130208_113005_078&VERSION=1.1.1
> When i specify the version in the GDAL request, e.g.
> <WCS_GDAL>
> <ServiceURL>http://193.175.162.189/geoserver/wcs?</ServiceURL>
> <CoverageName>raster_example_20130208_113005_078</CoverageName>
> <Version>1.1.0</Version>
> </WCS_GDAL>
> i get the response:
> C:\OSGeo4W\bin>gdalinfo wcs.xml
> ERROR 1: java.lang.IllegalArgumentException: The specified dimensional
> parameter is non-positive.
> The specified dimensional parameter is non-positive.
> gdalinfo failed - unable to open 'wcs.xml'.
> I asked this with a other background in the Geoserver-user list:
http://osgeo-org.1560.n6.nabble.com/Issue-with-noValue-in-WCS-coverageOfferings-tp5033051.html
> and it seems, GDAL does not consider the axis swiching in WCS 1.1.x
> It is possible to specify (or add) the axis order in the GDAL request?
> Has someone a solution or a idea for this?
> Thanks in advance
> Robert
I tried to investigate this case a bit on the Geoserver user list. The java
illegal argument error comes from Geoserver and because GDAL is sending BBOX
coordinates in lat-lon order.
This is captured from the GetCoverage request that was sent by gdalinfo
BOUNDINGBOX=-116.917,32.41666843,-116.75033333,32.5833351,
urn:ogc:def:crs:EPSG::4326
However, I feel it may be because a bit earlier the same Geoserver has
responded to DescribeCoverage request that was sent by GDAL as
<wcs:GridCRS><wcs:GridBaseCRS>urn:ogc:def:crs:EPSG::4326</wcs:GridBaseCRS>
<wcs:GridType>urn:ogc:def:method:WCS:1.1:2dGridIn2dCrs</wcs:GridType>
<wcs:GridOrigin>-116.91699999999997 32.5833351</wcs:GridOrigin>
<wcs:GridOffsets>0.16666667 0.0 0.0 -0.16666667</wcs:GridOffsets>
<wcs:GridCS>urn:ogc:def:cs:OGC:0.0:Grid2dSquareCS
</wcs:GridCS></wcs:GridCRS>
Does gdalinfo build the little GetCoverage request it is sending based on the
GridOrigin metadata it has queried from WCS server? And is this case the real
reason for the trouble caused by the wrong GridOrigin and GridOffsets metadata?
-Jukka Rahkonen-
