[gdal-dev] gdalwarp -rpc and RPC_DEM results and .TIL files
Even Rouault even.rouault at mines-paris.org
Sat Feb 9 05:22:31 PST 2013
> Since GDAL does not support the .TIL file,
Huh, there *IS* a TIL driver (frmts/til/tildataset.cpp) and I can see that it
tries to load the associated .RPB file.
However the manual procedure you used shouldn't change things fundamentally,
and I wouldn't expect directly using the TIL file will give better results.
There are perhaps some improvements/fixes to do in the RPC warper.
