[gdal-dev] gdalwarp -rpc and RPC_DEM results and .TIL files
Dmitriy Baryshnikov bishop.dev at gmail.com
Sat Feb 9 11:36:50 PST 2013
Hi Ivan,
I orthorectify such products with comparable with Envi results. But,
exist TIL driver usually have SRS WGS84 and output raster lost in
resolution on Y Axis. I correct driver and commit it (see ticket #3482
for details). Everything should be OK.
Also you need to add RPC_HEIGHT with some value to correct geoid.
http://translate.google.ru/translate?sl=auto&tl=en&js=n&prev=_t&hl=ru&ie=UTF-8&eotf=1&u=http%3A%2F%2Fgis-lab.info%2Fqa%2Forbview3-ortho-gdal.html&act=url
Best regards,
     Dmitriy
09.02.2013 3:33, Ivan Lucena пишет:
> Hi there,
> Does anybody has ever tried to orthorectify an "Ortho Ready Standard"
> QuickBird image with .TIL files?
> To whom might be interested, there is a couple of sample data on
> digitalglobe.com and you can always find DEM on USGS.COM.
> Contrary to GDAL standards :) in most of those sample dataset the .RPB
> file are not directed associated to the Geotiff file. Like in
> some_file_name.tif
> some_file_name.rpb
> That is usually the case when the scene covered is too big and the
> data provider decided to dived it on tiles.
> The .TIL file describe the offsets in lines/pixel/X/Y of each of the
> tiles and the .RPB is related to the .TIL file. Like in:
> some_file_t1.tif
> some_file_t2.tif
> some_file_t3.tif
> some_file_name.til
> some_file_name.rpb
> Since GDAL does not support the .TIL file, what one needs to do is to
> use gdalbuildvrt to create a VRT to represent the same tilling as the
> .TIL file.
> At that point it is still not ready to do orthorectification yet
> because gdalwarp doesn't seems to digest the combination .VRT .RPB.
> some_file_name.vrt
> some_file_name.rpb
> But that is just a matter of converting the VRT to GTIFF and go ahead
> and run:
> gdalwarp some_file_name.tif the_output_name.tif -rpc -to
> RPC_DEM=the_dem_file.tif -t_srs EPSG:32610
> But after all that I can't see much more accuracy when overlaying a
> vector road map on top of the original non-orthorectified than over
> the orthorectified output. It is a little bit better in some places
> but worse in some others.
> I found much better results with datasets without tilling. I mean,
> without .TIL files. Just one GTIFF and one .RPB
> Has anybody had that same experience?
> Do we have plans to support the .TIL file in GDAL?
> Best regards,
> Ivan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
