[gdal-dev] Converting ecw to tif for Geoserver
Paul Meems bontepaarden at gmail.com
Sun Feb 10 11:54:59 PST 2013
Thanks Andrea,
I didn't understand that the first time.
So there is no way to have the raster on top of another layer without
getting white areas?
In that case I will upload the smaller tiff file ;)
Paul
2013/2/10 Andrea Aime <andrea.aime at geo-solutions.it>
> On Sun, Feb 10, 2013 at 8:30 PM, Paul Meems <bontepaarden at gmail.com>wrote:
>> I don't see anything about compression.
>> Did I loose it along the way? Or is it expected to have such a large
>> sized end result.
>> Because it is now so large I think I'll get into trouble when I add it to
>> Geoserver. I hoped to use the tiff directly and not use Geoserver's pyramid
>> plug-in.
> As said before, GeoServer cannot recognize the GDAL alpha mask, so even if
> you manage to load it (it's a BigTIFF, it should
> be possible to load it, we tested TIFFs up to 100GB) you'll lose
> transparency anyways.
> Cheers
> Andrea
> Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
> information.
> Ing. Andrea Aime
> @geowolf
> Technical Lead
> GeoSolutions S.A.S.
> Via Poggio alle Viti 1187
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39  339 8844549
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130210/5bc45089/attachment.html>
