[gdal-dev] OGR WFS from behind NTLMv2 proxy server
Jeremy Palmer JPalmer at linz.govt.nz
Sun Feb 17 17:45:05 PST 2013
Is it possible to connect to a WFS server when behind an NTLMv2 proxy server?
I've tried setting the http_proxy to http://user:pass@host:port but I got this response (which makes it look like the credentials were not passed)
ERROR 1: HTTP error code : 407
ERROR 1: Error returned by server : HTTP error code : 407 (0)
FAILURE:
Cheers,
Jeremy Palmer
LINZ Data Service Manager
Landonline & Geospatial Services
E  jpalmer at linz.govt.nz<mailto:jpalmer at linz.govt.nz> | DDI +64 4 4983537 | M +64 27 2747 862
Wellington Office, Level 7, Radio New Zealand House, 155 The Terrace
PO Box 5501, Wellington 6145, New Zealand | T 04 460 0110
W  www.linz.govt.nz<http://www.linz.govt.nz/> | data.linz.govt.nz
[http://www.linz.govt.nz/sites/default/files/images/email-signature-v2.png]<http://www.linz.govt.nz/>
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130218/3417cadd/attachment-0001.html>
Type: image/png
Desc: email-signature-v2.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130218/3417cadd/attachment-0001.png>
