[gdal-dev] Multiple extensions in GDAL_DMD_EXTENSION ?
Etienne Tourigny etourigny.dev at gmail.com
Tue Feb 19 09:39:59 PST 2013
It would be nice to be able to specify many extensions in a
comma-separated list such as "nc,cdf,nc4". It can probably be done
(metadata is just a string), but isn't standard.
The Gdal driver tutorial states:
GDAL_DMD_EXTENSION: The extension used for files of this type. If more
than one pick the primary extension, or none at all. (optional)
It could be beneficial to extend this definition for multiple
extensions separated by comma.
cheers
Etienne
On Tue, Feb 19, 2013 at 11:26 AM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> I am not aware of a way to list multiple extensions.
> Best regards,
> On Feb 19, 2013 2:15 AM, "Oyvind Idland" <oyvind.idland at gmail.com> wrote:
>> Is it possible to specify multiple file extensions in GDAL_DMD_EXTENSION ?
>> I ask because I am working on a driver for a format that has several known
>> file extensions.
>> - Oyvind
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
