[gdal-dev] ogr utilities -dsco
Kyle Shannon kyle at pobox.com
Tue Feb 19 13:33:42 PST 2013
Use one -dsco flag for each option:
ogr2ogr -f KML impaired_streams_2010.kml impaired_2010_streams.shp
-dsco NameField=AUID -dsco DescriptionField=REACH_DESC
On Tue, Feb 19, 2013 at 2:26 PM, David Fawcett <david.fawcett at gmail.com> wrote:
> OK GDAL Devs, I give up.
> If I want to specify multiple -dsco key:value with OGR, what is the syntax?
> This works for one attribute:
> R:\mpca>ogr2ogr -f "KML" impaired_streams_2010.kml impaired_2010_streams.shp
> -ds
> co NameField=AUID
> But none of these work for two attributes:
> R:\mpca>ogr2ogr -f "KML" test.kml impaired_2010_streams.shp -dsco
> NameField=AUID,DescriptionField=REACH_DESC
> R:\mpca>ogr2ogr -f "KML" test2.kml impaired_2010_streams.shp -dsco
> NameField=AUID DescriptionField=REACH_DESC
> FAILURE: Couldn't fetch requested layer 'DescriptionField=REACH_DESC'!
> "NameField=AUID DescriptionField=REACH_DESC"
> R:\mpca>ogr2ogr -f "KML" test3.kml impaired_2010_streams.shp -dsco
> R:\mpca>ogr2ogr -f "KML" test4.kml impaired_2010_streams.shp -dsco
> "NameField=AUID,DescriptionField=REACH_DESC"
> Thanks,
> David.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
