[gdal-dev] gdal_polygonize and polygon edges
    Daniel Morissette
    dmorissette at mapgears.com
    Wed Feb 20 09:31:11 PST 2013
On 13-02-20 10:08 AM, Jeff Lacoste wrote:
> Daniel: Using 'SIA' technique sounds promising. Does it apply to
> polygons as well ? or just polylines ? I would be interested to test
> (and later use if applicable) your approach.
> If would like an extra tester, please let me know.
Yes, our implementation also works on polygons. i.e. For polygons, the
calculations for the points at the beginning of the line string also
take into account the points from the other end, and vice-versa.
We'll try to see how we could go about sharing what we've got at the
moment with you.
Daniel
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
