[gdal-dev] gdaladdo don't seem to work..
Pietro Rossin pierigis at gmail.com
Tue Feb 26 05:52:22 PST 2013
Ok, I found the answer for the aux/rrd pyramid here
http://lists.osgeo.org/pipermail/gdal-dev/2008-August/017850.html
Now I'm trying
Bie
2013/2/26 Pietro Rossin <pierigis at gmail.com>
> Hello Jukka
> thanks for your reply
> The axe file I think isn't necessary.
> If I delete it qgis can open and use pyramids...
> I got a good compromise between render and pyramid dimension with this
> command
> gdaladdo -r nearest --config COMPRESS_OVERVIEW deflate --config USE_RRD
> YES test.tif 4 16 32 64
> I get an aux file that is 420Mb (original gtiff is 1060Mb) and if I delete
> the .axe file qgis recognizes pyramids.
> the CCITTFAX4 compression method is good for the compression of the
> original image not for pyramids, because with this algorithm pyramid zoom
> is too dark. With deflate or jpeg the result is more pleasant.
> By the way
> --config USE_RRD YES should tell gdaladdo to create aux/rrd pyramids, that
> can be used with esri product (ex arcgis)
> Arcgis instead don't recognize these pyramids and asks if I want to create
> them (and it can't because of an unknown error..).
> Any idea?
> Thanks again
> Pietro
> View this message in context: Re: gdaladdo don't seem to work..<http://osgeo-org.1560.n6.nabble.com/gdaladdo-don-t-seem-to-work-tp5036638p5036957.html>
> Sent from the GDAL - Dev mailing list archive<http://osgeo-org.1560.n6.nabble.com/GDAL-Dev-f3742093.html>at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130226/b6fb621e/attachment.html>
