[gdal-dev] ogr WFS GML parse error with WFS 1.1.0
Jeremy Palmer JPalmer at linz.govt.nz
Wed Feb 27 00:34:43 PST 2013
Hi Jukka,
But that's legal XML and GML is it not?
Jeremy
________________________________________
From: gdal-dev-bounces at lists.osgeo.org [gdal-dev-bounces at lists.osgeo.org] On Behalf Of Jukka Rahkonen [jukka.rahkonen at mmmtike.fi]
Sent: Wednesday, 27 February 2013 6:23 p.m.
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] ogr WFS GML parse error with WFS 1.1.0
Jeremy Palmer <JPalmer <at> linz.govt.nz> writes:
> So could it be a http streaming issue?
Actually the error that is reported in your debug log file has happened also in
the same location: "mismatched tag at line 2, column 3621905"
That character in that column seems to be "/" in the beginning of the last
closing tag "</wfs:FeatureCollection>"
</gml:LinearRing>
</gml:interior>
</gml:Polygon>
</gml:polygonMember>
</gml:MultiPolygon>
</v:shape>
</v:x1571>
</gml:featureMembers>
-Jukka Rahkonen-
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
