[gdal-dev] Gdal : import .ecw into postgis database
image lcelati at latitude-geosystems.com
Thu Feb 28 06:41:07 PST 2013
Following to my last post. I just checked raster2pgsal -G. And there is not
ECW in the list, there is only 'ERMapper .ers Labelled'...so it seems my
gdal 's postgis did not compile with the ECW support...;-(
Moreover, when i do a SELECT postgis_full_version();
"POSTGIS="2.0.1 r9979" GEOS="3.3.5-CAPI-1.7.5" PROJ="Rel. 4.8.0, 6 March
2012" GDAL="GDAL 1.9.1, released 2012/05/15"
And my qgis 's gdal has been also compiled with gdal 1.9.1.
Moreover, for information, my GDAL_DATA (environment system variable)
pointed to C:\Program Files\PostgreSQL\9.1\gdal-data
Thanks.
Laurent.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Gdal-import-ecw-into-postgis-database-tp5037040p5037519.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
