[gdal-dev] gdalinfo and ogrinfo file formats
Paul Meems bontepaarden at gmail.com
Wed Jan 2 06:50:00 PST 2013
Thanks Even,
I'll have a look at your suggestions.
BTW for MapWindow we don't use the GDAL C# API.
>From our C#/Winforms we 'talk' to our MapWinGIS wich is a C++ ActiveX
control.
MapWinGIS does the communication with GDAL. This is much faster and more
stable than using C# bindings.
Thanks,
Paul
 *Paul Meems *
Release manager, configuration manager
and forum moderator of MapWindow GIS.
www.mapwindow.org
Owner of MapWindow.nl - Support for
Dutch speaking users.
www.mapwindow.nl
2013/1/2 Even Rouault <even.rouault at mines-paris.org>
> Selon Paul Meems <bontepaarden at gmail.com>:
> > Hi Even,
> > I'm not sure why I shouldn't use --format. If I can't use it why is it
> > provided?
> > Can I use --formats?
> My message was that the output format of gdalinfo is primarly for humans,
> not to
> be fed into other software. Well, this is my vision. You can do whatever
> you
> want of course. (Hint: QGIS uses the C API to feed its Open raster dialog)
> > Perhaps I should not handle this in my C#/WinForms but do this in our C++
> > core.
> You can probably use the GDAL C# API. This is basically just iterating
> over the
> drivers and querying the relevant metadata keys. Should be pretty similar
> to the
> C++ code.
> > I think we can make a method that would return what I need based on
> > gcore/gdal_misc.cpp but that would rely on hard-coded strings.
> > I don't like that either ;)
> By hard-coded strings, do you mean GDAL_DMD_EXTENSION and such strings ?
> Well,
> they are part of the GDAL API, so they shouldn't change in the foreseable
> future. They are also available in SWIG bindings (something like
> Gdal.DMD_EXTENSION but I'm not sure, as I don't use the C# bindings myself)
> > For the formats for ogr2ogr I understand I need to use a workaround so I
> > could do that for the gdal formats as well.
> > The whole idea is/was that when we upgrade to a newer version of GDAL/ORG
> > or recompile it with some different settings our tools would
> automagically
> > use the correct file formats.
> Yes, I understood that. For OGR drivers, for now, you'll have to hardcode
> the
> information (or put it into a config file with the relevant information).
> For
> GDAL drivers, you can use the API to dynamically query the information.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130102/b0721c42/attachment.html>
