[gdal-dev] ENVI datasets with rotation
Carl Godkin cgodkin at gmail.com
Thu Jan 3 06:05:15 PST 2013
Happy 2013 everyone,
We've come across some ENVI data sets (.bsq + .hdr files) in which the "map
info" keyword of the .hdr file looks like this:
map info = {UTM, 1, 1,  408953.26, 3290904.2,  3.400, 3.400, 17,  North,
 WGS-84,  units=Meters,  rotation=-6.00000}
It's interesting because we have a collection of seven such files and only
two of them have rotation values other than 0.
We're using GDAL 1.9.2 and frmts/raw/envidataset.cpp, which seems to parse
the .hdr file in this case, ignores the rotation.
The code that captures the geotransform sets the two rotation terms to 0
unconditionally so it seems like it might not be
too difficult to fix this.
Besides adjusting the geotransform, it looks like the code at bottom
of ENVIDataset::ProcessMapinfo() would need to be fixed since the "units="
term is not actually always last in the map info array.
Has someone else already done anything about this already?  (E.g., is there
a patch awaiting approval somewhere?)
Thanks very much for any advice on this.
carl
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130103/99794c79/attachment.html>
