[gdal-dev] Ogr and setSpatialFilter
Kees kling ckling at upcmail.nl
Thu Jan 3 06:12:42 PST 2013
On 01/03/2013 03:06 PM, Even Rouault wrote:
> Selon Kees kling <ckling at upcmail.nl>:
>> Hi,
>> last week I upgraded my ubuntu and also the gdal library. I was using
>> version libgdal.so.1.15.0, now I compiled and installed version
>> libgdal.so.1.16.2.
>> In my application i'm using OGRLayer SetSpatialFilter and it was working
>> in the old version, but in the new version the GetFeatureCount returns 0
>> so nothing is plotted. Is there a change in the function between these
>> two versions?
> Check :
> ldd /path/to/libgdal.so.1.15.0 | grep geos
> and
> ldd /path/to/libgdal.so.1.16.2 | grep geos
> My guess is that the first returns something, whereas the second doesn't. In
> which case, you might need to install the developement package of GEOS and
> rebuild GDAL against it.
>> Thanks
>> Kees Kling
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
I compiled both libs with geos support and the loader gives me
     libgeos_c.so.1 => /usr/lib/libgeos_c.so.1 (0x00007fe171f78000)
     libgeos-3.2.2.so => /usr/lib/libgeos-3.2.2.so (0x00007fe16f29f000)
so that won't be  the problem.
Kees
