[gdal-dev] Ogr and setSpatialFilter
Kees kling ckling at upcmail.nl
Thu Jan 3 06:26:41 PST 2013
On 01/03/2013 03:16 PM, Even Rouault wrote:
>> I compiled both libs with geos support and the loader gives me
>>       libgeos_c.so.1 => /usr/lib/libgeos_c.so.1 (0x00007fe171f78000)
>>       libgeos-3.2.2.so => /usr/lib/libgeos-3.2.2.so (0x00007fe16f29f000)
>> so that won't be  the problem.
> hum, then you must provide a way to reproduce that behaviour ( script/command
> line + data )
>> Kees
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
That is not that easy, because it is embedded in in c++ applications.
Meanwhile I reinstalled the old version and can go on with my work, but
i think there is something wrong
