[gdal-dev] ogr2ogr
Uffe Kousgaard uffe at routeware.dk
Fri Jan 4 02:17:43 PST 2013
Hello,
Thank you, yes I had just found the exe files in a sub folder.
But it still doesn't write the TAB file correct.
If I use MIF instead as output format, it changes Numeric(4,0) fields
into Integer(4). There is no such thing as Integer(4) in MIF.
It is either Decimal(4,0) or just Integer / SmallInt. But at least the
UTF-8 strings come out correct.
So, it seems like being a matter of incorrect writing of TAB and MIF
rather than reading the SHP and codepage.
Regards
Uffe Kousgaard
Yves Jacolin wrote:
> Hello,
> You see this website : http://www.gisinternals.com/sdk/
> or this one : http://trac.osgeo.org/gdal/wiki/DownloadingGdalBinaries
> (see Windows and OSGeo4W sections).
> Y.
> Le vendredi 4 janvier 2013 10:47:29 Uffe Kousgaard a écrit :
>> Where can I find the most recent precompiled ogr2ogr package for windows?
>> I am still using the one in fwtools 2.4.7 (almost 3 years old) and I
>> have some utf-8 encoded SHP files, which it doesn't seem to handle well.
>> I have tried with cpg files, but no luck.
>> Regards
>> Uffe Kousgaard
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
