[gdal-dev] DBF handling
Even Rouault even.rouault at mines-paris.org
Fri Jan 4 03:54:28 PST 2013
Selon Uffe Kousgaard <uffe at routeware.dk>:
> When DBF files has numeric fields with values > 2GB, processing fails
> and all values come out as -2147483648.
> My current work-around is manually changing the fields from Numeric to
> Char (changing the header of the DBF), but it is really an ugly hack and
> spaces for padding are wrong (numeric fields are right-aligned, while
> char-fields are left-aligned internally).
> It would be nice if at least int64 was used for integers in OGR, rather
> than int32. Large integers are typically used as identifiers in
> databases such as TomTom, OSM etc.
> Has this been reported before?
Yes, this is a known issue that should be fixed in a future version (GDAL 2.0 ?)
when support for 64bit integers is added (
http://trac.osgeo.org/gdal/wiki/rfc31_ogr_64) . There's no software workaround
on OGR side for now.
> Regards
> Uffe Kousgaard
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
