[gdal-dev] ogr2ogr
Daniel Morissette dmorissette at mapgears.com
Fri Jan 4 04:58:20 PST 2013
As Yves pointed out, this is a known issue, actually a regression in the
MITAB driver introduced in GDAL 1.9.x:
  https://trac.osgeo.org/gdal/ticket/3853
Daniel
On 13-01-04 5:17 AM, Uffe Kousgaard wrote:
> Hello,
> Thank you, yes I had just found the exe files in a sub folder.
> But it still doesn't write the TAB file correct.
> If I use MIF instead as output format, it changes Numeric(4,0) fields
> into Integer(4). There is no such thing as Integer(4) in MIF.
> It is either Decimal(4,0) or just Integer / SmallInt. But at least the
> UTF-8 strings come out correct.
> So, it seems like being a matter of incorrect writing of TAB and MIF
> rather than reading the SHP and codepage.
> Regards
> Uffe Kousgaard
> Yves Jacolin wrote:
>> Hello,
>> You see this website : http://www.gisinternals.com/sdk/
>> or this one : http://trac.osgeo.org/gdal/wiki/DownloadingGdalBinaries
>> (see Windows and OSGeo4W sections).
>> Y.
>> Le vendredi 4 janvier 2013 10:47:29 Uffe Kousgaard a écrit :
>>> Where can I find the most recent precompiled ogr2ogr package for
>>> windows?
>>> I am still using the one in fwtools 2.4.7 (almost 3 years old) and I
>>> have some utf-8 encoded SHP files, which it doesn't seem to handle well.
>>> I have tried with cpg files, but no luck.
>>> Regards
>>> Uffe Kousgaard
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
