[gdal-dev] Reprojecting GeoTIFFs with Overviews?
Jason Greenlaw - NOAA Affiliate jason.greenlaw at noaa.gov
Thu Jan 10 10:03:33 PST 2013
Norman,
Unfortunately that's not an option - In this case, my overviews are
generated separately as individual .ovr files, e.g.:
NGOFS_WL.tif
NGOFS_WL.tif.ovr
NGOFS_WL.tif.ovr.ovr
NGOFS_WL.tif.ovr.ovr.ovr
NGOFS_WL.tif.ovr.ovr.ovr.ovr
I'm then stitching them together into a single image with gdal_translate
-co COPY_SRC_OVERVIEWS=YES  before attempting to reproject the result.
Here's an example of what it looks like:
http://jgreenlaw.org/gdal/ngofs-wl.png
In each overview, the "streaklet" arrows actually need to be rendered at
the proper resolution; I can't simply interpolate the original image.
Perhaps I'm out of luck and need to reproject each of the .ovr files and
the .tif files separately before combining them?
Jason
Jason Greenlaw
Contractor, ERT, Inc.
NOAA/NOS/OCS/CSDL
http://nowcoast.noaa.gov
Jason.Greenlaw at noaa.gov
(603) 862-3560
On Thu, Jan 10, 2013 at 12:37 PM, Norman Vine <nhv at cape.com> wrote:
> Jason
> you need to make overviews for the reprojected image
> see
> http://www.gdal.org/gdaladdo.html
> On Jan 10, 2013, at 12:20 PM, Jason Greenlaw - NOAA Affiliate <
> jason.greenlaw at noaa.gov> wrote:
> Using gdalwarp I'm attempting to reproject a 4-band (RGBA) GeoTIFF (in
> EPSG:4269) containing 4 overviews to web mercator (EPSG:3857).  While the
> reprojection seems to work fine for the image itself, it appears the
> overviews are not being reprojected/carried over to the new reprojected
> GeoTIFF.
> I've tried specifying -co COPY_SRC_OVERVIEWS=YES to gdalwarp, but it still
> results in the overviews being lost.
> I am using GDAL 1.9.2.
> Is this the expected behavior?  Is there perhaps some way to ask gdalwarp
> to also reproject the overviews?  Or do I have to reproject each overview
> individually, then merge them into a single GeoTIFF with gdal_translate?
> Any help/information would be greatly appreciated.
> Here is the gdalwarp command I'm using (esri-3857.prf contains custom
> EPSG:3857 WKT to be compatible with ESRI software):
> gdalwarp -s_srs EPSG:4269 -t_srs esri-3857.prf -r bilinear -co
> COMPRESS=LZW -co COPY_SRC_OVERVIEWS=YES -overwrite NGOFS_WL_4269.tif
> NGOFS_WL_3857.tif
> Below are the output of gdalinfo for both the source and reprojected
> GeoTIFFs.
> $ gdalinfo NGOFS_WL_4269.tif
> Driver: GTiff/GeoTIFF
> Files: NGOFS_WL_4269.tif
> Size is 3000, 1255
> Coordinate System is `'
> Origin = (-97.401951999999994,30.701952500000001)
> Pixel Size = (0.003900000000000,-0.003903000000000)
> Image Structure Metadata:
>   COMPRESSION=LZW
>   INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left  ( -97.4019520,  30.7019525)
> Lower Left  ( -97.4019520,  25.8036875)
> Upper Right ( -85.7019520,  30.7019525)
> Lower Right ( -85.7019520,  25.8036875)
> Center      ( -91.5519520,  28.2528200)
> Band 1 Block=3000x1 Type=Byte, ColorInterp=Red
>   Overviews: 1500x627, 750x313, 375x156, 187x78
>   Mask Flags: PER_DATASET ALPHA
>   Overviews of mask band: 1500x627, 750x313, 375x156, 187x78
> Band 2 Block=3000x1 Type=Byte, ColorInterp=Green
> Band 3 Block=3000x1 Type=Byte, ColorInterp=Blue
> Band 4 Block=3000x1 Type=Byte, ColorInterp=Alpha
> $ gdalinfo NGOFS_WL_3857.tif
> Files: NGOFS_WL_3857.tif
> Size is 2940, 1391
> Coordinate System is:
> PROJCS["WGS 84 / Pseudo-Mercator",
>     GEOGCS["WGS 84",
>         DATUM["WGS_1984",
>             SPHEROID["WGS 84",6378137,298.257223563,
>                 AUTHORITY["EPSG","7030"]],
>             AUTHORITY["EPSG","6326"]],
>         PRIMEM["Greenwich",0],
>         UNIT["degree",0.0174532925199433],
>         AUTHORITY["EPSG","4326"]],
>     PROJECTION["Mercator_1SP"],
>     PARAMETER["central_meridian",0],
>     PARAMETER["scale_factor",1],
>     PARAMETER["false_easting",0],
>     PARAMETER["false_northing",0],
>     UNIT["metre",1,
>         AUTHORITY["EPSG","9001"]],
>     EXTENSION["PROJ4","+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0
> +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext
>  +no_defs"],
>     AUTHORITY["EPSG","3857"]]
> Origin = (-10842735.698910875245929,3572289.254035749472678)
> Pixel Size = (443.061998399919901,-443.061998399919901)
> Metadata:
>   AREA_OR_POINT=Area
>   COMPRESSION=LZW
>   INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left  (-10842735.699, 3572289.254) ( 97d24' 7.03"W, 30d31'59.96"N)
> Lower Left  (-10842735.699, 2955990.014) ( 97d24' 7.03"W, 25d39' 5.65"N)
> Upper Right (-9540133.424, 3572289.254) ( 85d42' 1.72"W, 30d31'59.96"N)
> Lower Right (-9540133.424, 2955990.014) ( 85d42' 1.72"W, 25d39' 5.65"N)
> Center      (-10191434.561, 3264139.634) ( 91d33' 4.37"W, 28d 7'12.80"N)
> Band 1 Block=2940x1 Type=Byte, ColorInterp=Red
> Band 2 Block=2940x1 Type=Byte, ColorInterp=Green
> Band 3 Block=2940x1 Type=Byte, ColorInterp=Blue
> Band 4 Block=2940x1 Type=Byte, ColorInterp=Alpha
> Jason Greenlaw
> NOAA/NOS/OCS/CSDL
>  _______________________________________________
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130110/dcb9eede/attachment.html>
