[gdal-dev] does gdal support multiple simultaneous writers to raster
Thu Jan 10 17:32:50 PST 2013
Paul,
Generally speaking - no - GDAL does not now support multi-threaded
writing.  Part of this is due to the way stuff gets write-flushed out
of the block cache and partly it is just that none of GDAL supports
multiple threading on a single dataset.
This statement is based on the assumption it is all in one process.
If you want to run different processes with the output to a
pre-existing "fixed location" format like uncompressed GeoTIFF with
tiles that is all preinitialized to some real value then you could
certainly use one output file for many writers as long as case is
taken to not have multiple processes write to the same tile.  But GDAL
isn't doing anything to make this easy.
Best regards,
Frank
On Thu, Jan 10, 2013 at 4:12 PM, Kennedy, Paul <P.Kennedy at fugro.com.au> wrote:
> I am looking to parallelize a long duration gridding process, and was
> wondering if GDAL can support multiple simultaneous writers from processess?
> I am not sure if any of the underlying raster formats support this?
> thanks in advance.
> regards
> pk
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
and watch the world go round - Rush    | Geospatial Software Developer
