[gdal-dev] does gdal support multiple simultaneous writers to raster
Kennedy, Paul P.Kennedy at fugro.com.au
Fri Jan 11 17:38:55 PST 2013
Yes, we are pretty sure we will see a significant benefit.  The processing algorithms are CPU bound not io bound. Our digital terrain model interpolations often run for many hours ( we do them overnight) but the underlying file is only a few gigabytes. If we split them into multiple files of tiles and run each on a dedicated process the whole thing is quicker, but this is messy and results in a stitching error.
Another example is gdalwarp. It takes quite some time with a large data set and would be. A good candidate for parallelisation, as would gdaladdo.
I believe slower cores but more of them in pcs are the future. My pc has 8 but they rarely get used to their potential.
I am certain there are some challenges here, that's why it is interesting;)
Regards
pk
On 11/01/2013, at 6:54 PM, "Even Rouault" <even.rouault at mines-paris.org> wrote:
> Hi,
> This is an intersting topic, with many "intersecting" issues to deal with at
> different levels.
> First, are you confident that in the use cases you imagine that I/O access won't
> be the limiting factor, in which case serialization of I/O could be acceptable
> and this would just require an API with a dataset level mutex.
> There are several places where parallel write should be addressed :
> - The GDAL core mechanisms that deal with the block cache
> - Each GDAL driver where parallel write would be supported. I guess that GDAL
> drivers should advertize a specific capability
> - The low-level library used by the driver. In the case of GDAL, libtiff
> And finally, as Frank underlined, there are intrinsic limitations due to the
> format itself. For a compressed TIFF, at some point, you have to serialize the
> writing of the tile, because you cannot kown in advance the size of the
> compressed data, or at least have some coordination of the writers so that a
> "next offset available" is properly synchronized between them. The compression
> itself could be serialized.
> I'm not sure however if what Jan mentionned, different process, writing the same
> dataset is doable.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130112/866e983e/attachment.html>
