[gdal-dev] does gdal support multiple simultaneous writers to raster
Jan Hartmann j.l.h.hartmann at uva.nl
Mon Jan 14 06:38:29 PST 2013
Thanks Frank, that's what I have been doing until now. I was hoping that
GDAL could do some of the bookkeeping for me.
Bu the multithreaded issue remains important. Anything that could speed
up the warping process, for whatever configuration, would be welcome and
I would be happy to assist.
Jan
On 14-1-2013 15:32, Frank Warmerdam wrote:
> Jan,
> While it is desirable to resolve the multithreaded write issue in gdal
> I don't think it is critical for your use case.
> I think your case would be handled more appropriately by multiple
> *processes*.  You would still run into issues with write consistency
> but of a different nature.  The easiest approach is to assign
> different spatial regions to each worker server and run these linearly.
> Best regards,
> On Jan 12, 2013 8:05 AM, "Jan Hartmann" <j.l.h.hartmann at uva.nl
> <mailto:j.l.h.hartmann at uva.nl>> wrote:
>     I would be interested in an implementation. I'm preparing a
>     proposal to georeference the complete cadastral map of the
>     Netherlands in 1832 at a 10 cm/pixel scale with Cloud facilities.
>     Gdalwarp is the central piece of software, and distributed
>     processing capabilities would be very important. Could you please
>     think about the possibilities, and what kind of funding would be
>     required, so I can take that in during the next few months?
>     Jan
>     On 01/12/2013 04:35 PM, Even Rouault wrote:
>>>     ex. convert
>>>     multiple datasets to different output datasets in a parallel way.
>>     As Frank underlined, there's currently an issue with the global block cache
>>     regarding write support.
>>     Imagine that you have 2 threads A and B.
>>     Thread A deal with dataset A, and thread B deal with dataset .
>>     Thread A is in the middle of writing some tile/line of dataset A.
>>     Thread B is trying to fill a new entry in the block cache (with new read data,
>>     or new data to write). But the block cache is full. So the last recently used
>>     entry must be discarded. If that entry is a dirty block of dataset A, then it
>>     must be flushed to disk, in the context of thread B, but at that time thread A
>>     is also writing data... Which might be an issue since drivers are re-entrant
>>     (can be invoked by multiple threads, if each thread deal with different
>>     datasets) not thread-safe.
>>     This specific case here could be fixed in different ways :
>>     A) Making drivers thread-safe (or accessing them through a thread-safe layer),
>>     that is to say add a dataset level mutex
>>     B) or having a per-dataset block cache instead of a global block cache
>>     C) deal differently with dirty blocks. Only flush them if the operation that
>>     need to discard the dirty block is initiated by an operation on the same
>>     dataset as the dirty block.
>>>     Would
>>>     those parallel operations not be affected by GDAL caching for bot read and
>>>     write.Since the cache is set to a limit. Is Accessing the current used
>>>     cache value concurrent safeto increase it/decrease it ?
>>     Hum, I see that GDALGetCacheMax() and GDALSetCacheMax() are not thread safe
>>     currently. We would need to protect them by the raster block mutex, with a
>>     leading call to CPLMutexHolderD(&hRBMutex );
>>     _______________________________________________
>>     gdal-dev mailing list
>>     gdal-dev at lists.osgeo.org  <mailto:gdal-dev at lists.osgeo.org>
>>     http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130114/55be1500/attachment-0001.html>
