[gdal-dev] RPC transform
Wed Jan 16 10:47:59 PST 2013
Yehiyam,
I do not see why you think the AREA_OR_POINT value ought to have any
influence on how DEM values are interpolated.
Note that a PixelIsPoint GeoTIFF file will already result in a GDAL
GeoTransform that is offset by half a pixel.  The GDAL GeoTransform always
treats pixels as areas, and GDAL interpolators - presumably including the
for RPCs - should treat the pixel value as being at the center of the pixel
area for the purpose of interpolation (regardless of whether that value is
point or area).
On the other hand, I am denying the possibility that the RPC DEM
interpolation is always off by half a pixel.  I haven't actually looked
closely at that code lately and the RPC code is not so very well tested and
validated.
Best regards,
Frank
On Wed, Jan 16, 2013 at 4:40 AM, Livneh Yehiyam <yehil at rafael.co.il> wrote:
>  Hi****
> I have a question about the RPC transform implemented in gdal_rpc.cpp.****
> If a dem file is specified in the transform options (RPC_DEM) the file is
> sampled to retrieve the elevation of the transformed point.****
> In the case where the dem file is a DTED file (which defines AREA_OR_POINT
> to POINT), shouldn't the pixel/line values in the dem file be offset by
> half a pixel to get the correct height?****
> Thanks****
> Yehiyam****
>  ________________________________________
> This message (including any attachments) issued by RAFAEL- ADVANCED
> DEFENSE SYSTEMS LTD. (hereinafter "RAFAEL") contains confidential
> information intended for a specific individual and purpose, may constitute
> information that is privileged or confidential or otherwise protected from
> disclosure. If you are not the intended recipient, you should contact us
> immediately and thereafter delete this message from your system. You are
> hereby notified that any disclosure, copying, dissemination, distribution
> or forwarding of this message, or the taking of any action based on it, is
> strictly prohibited. If you have received this e-mail in error, please
> notify us immediately by e-mail mailto:lawraf at rafael.co.il and completely
> delete or destroy any and all electronic or other copies of the original
> message and any attachments thereof.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130116/ab794ee1/attachment.html>
