[gdal-dev] Giventiff with colortable, how do i assign one of the colors to be an alpha channel
Even Rouault even.rouault at mines-paris.org
Wed Jan 16 12:23:17 PST 2013
Le mercredi 16 janvier 2013 21:21:29, Isaac Gerg a écrit :
> I mispoke.
> rgb2pct.py will work but only on RGB images -- no colortables.  When I use
> it on a RGBA image, the transparency is no longer preservered.
Combine it with the first hints I gave
