[gdal-dev] Giventiff with colortable, how do i assign one of the colors to be an alpha channel
Isaac Gerg isaac.gerg at gergltd.com
Wed Jan 16 12:42:52 PST 2013
To be clear, suppose I want to make the red bow in the image below as a
tiff file with transparency. But instead of using RGBA, can tiff create it
with indexed color?
http://d241yswl6yg9sc.cloudfront.net/remove-background2/4.png
Isaac
On Wed, Jan 16, 2013 at 3:40 PM, Isaac Gerg <isaac.gerg at gergltd.com> wrote:
> Even,
> I am confused.  You said in your first response to me that TIFF does not
> support indexed colormaps of RGBA. Am I understanding you correctly -- it
> sounds like it is not possible to create an indexed color TIFF that has
> background transparency.  Is this correct?
> Isaac
> On Wed, Jan 16, 2013 at 3:23 PM, Even Rouault <
> even.rouault at mines-paris.org> wrote:
>> Le mercredi 16 janvier 2013 21:21:29, Isaac Gerg a écrit :
>> > I mispoke.
>> > rgb2pct.py will work but only on RGB images -- no colortables.  When I
>> use
>> > it on a RGBA image, the transparency is no longer preservered.
>> Combine it with the first hints I gave
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130116/487b1865/attachment.html>
