[gdal-dev] Creating Raster using Spatial Coordinates (Latitude and Longitude)
Chaitanya kumar CH chaitanya.ch at gmail.com
Thu Jan 17 00:33:21 PST 2013
Dheeraj,
OGR's CSV driver[1] can read your vector data.
You have to decide how to represent your data in a raster. Interpolate
missing areas, set nodata pixels or something else.
Have a look at the gdal_rasterize utility[2].
[1]: http://www.gdal.org/ogr/drv_csv.html
[2]: http://www.gdal.org/gdal_rasterize.html
On Thu, Jan 17, 2013 at 5:56 AM, Dheeraj Reddy Mamidi <
drmamidi at rothwellgroup.com> wrote:
> I am using C# Gdal library.
> On Wed, Jan 16, 2013 at 5:25 PM, Dheeraj Reddy Mamidi <
>> Hi,
>> I am trying to create a Raster using grid of points(with latitude and
>> longitude values) within an area which are separated at a distance measured
>> in degrees. At higher latitudes the number of samples reduce that is number
>> of points for a row reduces.
>> When distance between points is determined with a fixed degree, how do I
>> create a raster where the number of columns for higher latitudes reduces ?
>> In this case, points for grid at higher latitudes are not exactly above the
>> points at lower latitudes. Can some one suggest a way to create raster for
>> spatial coordinates in this case?
>> Thanks,
>> Dheeraj
> Software Developer
> The Rothwell Group, L.P.
> Email: drmamidi at rothwellgroup.com <atvaughan at rothwellgroup.com>
> Phone: 713-952-5355 ext.30
> Web: www.rothwellgroup.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130117/2c75abb2/attachment.html>
