[gdal-dev] Creating a nadgrid shift file
Jan Hartmann j.l.h.hartmann at uva.nl
Thu Jan 17 09:10:40 PST 2013
(Sorry for crossposting, don't know if it is a gdal or proj problem )
This has been discussed on this list some time ago. I have been able to
create a working nadgrid file with gdal, but it doesn't return the right
coordinates. I did it as follows:
- create a 4 band, float32 geotif, each pixel with the displacements in
lat, lon (arcseconds), errorx and errory (both zero)
- gdal-translate it to ntv2-format.
The displacements in the geotiff are correct, and proj returns shifted
coordinates when using the ntv2-file, but not on the right location. I'm
really out of my wits. Could it have something to do with ntv2 using
negative lon-values east of Greenwich? Any help would be appreciated.
Jan
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130117/a57c994f/attachment-0001.html>
