[gdal-dev] creating bounding box map of a contour map
Hermann Peifer peifer at gmx.eu
Thu Jan 24 07:15:06 PST 2013
On 2013-01-24 11:44, Ahmet Temiz wrote:
> hello
> I have a contour elevation (line) map.
> I create bounding box map ( as a rectangular  polygon ) of this
> contour map using extend.
> how can I do that ?
If I understood correctly, all you need to do is:
ogrtindex output_dataset src_dataset
http://www.gdal.org/ogrtindex.html
Hermann
