[gdal-dev] libFileGDBAPI.so not found with compiling gdal 1.9.2 on openSUSE 12.2 x64.
Jan Heckman jan.heckman at gmail.com
Fri Jan 25 00:19:27 PST 2013
On windows, using visual studio (2008 and 2012), I could compile both 32
bits and 64 bits, but only the 32 bits version actually worked.
I haven't tried to figure out why the 64 bits version didn't work, 32 bits
was good enough for me.
Hope this is an option for you as well,
Jan
On Fri, Jan 25, 2013 at 5:23 AM, Donovan Cameron <sault.don at gmail.com>wrote:
> Looks like over in the [qgis-user] list, someone is having similar
> problems:
> https://groups.google.com/d/msg/qgis_user_remote/B2J9sOsSLbo/BIpAHZ84bhgJ
> On Thu, Jan 24, 2013 at 9:05 PM, Donovan Cameron <sault.don at gmail.com>
> wrote:
> > I can't seem to compile GDAL with FileGDB support on openSUSE.
> > I'm compiling locally using the OBS tools (osc) and have checked-out
> > the libgdal package from the Application:Geo project.
> > Steps I've taken:
> > 1) Download FileGDB_API_1_2-64.tar.gz
> > 2) tar xzvf FileGDB_API_1_2-64.tar.gz -C /usr/lib64/
> > 3) export LD_LIBRARY_PATH=/usr/lib64/FileGDB_API/lib
> > cd /usr/lib64/FileGDB_API/samples
> > make
> > cd bin
> > ./Querying #Works, so the API is fine.
> > 4) su -
> > $ vi /etc/ld.so.conf.d/fgdb.conf #Added a single entry:
> > $ ldconfig #A grep of this with the -v flag shows it registered fine
> > 5) #Some openSUSE specific stuff, b/c I'm building locally via the OBS
> > $ zypper in osc
> > cd /home/saultdon/Development/obs
> > osc co Application:Geo libgdal
> > cd Application:Geo/libgdal
> > vi libgdal.spec #added "--with-fgdb=/usr/lib64/FileGDB_API" in
> > %configure section
> > #I also did a test build without that configure param. first and it
> > compiled fine with working RPMs
> > osc build openSUSE_12.2 x86_64 libgdal.spec --clean
> > Resulting Error:
> > [  209s] checking for libFileGDBAPI.so in in
> > /usr/lib64/FileGDB_API/lib... configure: error: not found.
> > [  209s] error: Bad exit status from /var/tmp/rpm-tmp.7SOa8g (%build)
> > [  209s] RPM build errors:
> > [  209s] Bad exit status from /var/tmp/rpm-tmp.7SOa8g (%build)
> > The buildroot was: /var/tmp/build-root
> > libFileGDBAPI.so file exists, ldconfig registered it, and the API test
> > worked fine, the env. var. LD_LIBRARY_PATH is also set, but I don't
> > even think that's necessary. I only had to set that to get the API
> > test to work.
> > I'm not sure where this is going wrong. If anyone has any input or
> > needs more information, let me know.
> > Thanks!
> > Donovan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130125/40366321/attachment-0001.html>
