[gdal-dev] fails to build with popler trunk
Joaquim Luis jluis at ualg.pt
Mon Jan 28 08:09:30 PST 2013
Thanks Even
I have a fresh gdal but since I use a nmake.local file, I hadn't noticed
the new POPPLER_0_23_OR_LATER=YES
Unfortunately, with it declared I still get one error:
pdfdataset.cpp(1036) : error C2664: 'SplashOutputDev::startDoc' : cannot
convert parameter 1 from 'XRef *' to 'PDFDoc *'
         Types pointed to are unrelated; conversion requires
reinterpret_cast, C-style cast or function-style cast
pdfdataset.cpp(2785) : error C3861: 'setErrorFunction': identifier not found
> On 13-01-28 11:47 AM, Even Rouault wrote:
>> As documented in nmake.opt, adding POPPLER_0_23_OR_LATER=YES in nmake.local
>> should fix it. Upgrade both your GDAL trunk and poppler git to the latest
>> versions. Support for the latest poppler git is in the very last revisions of
>> GDAL trunk.
> Good to know, thanks Even for your good work.
> -jeff
