[gdal-dev] fails to build with popler trunk
Joaquim Luis jluis at ualg.pt
Mon Jan 28 10:10:09 PST 2013
>> Did you define POPPLER_0_20_OR_LATER=YES and
>> POPPLER_BASE_STREAM_HAS_TWO_ARGS =
>> YES and POPPLER_HAS_OPTCONTENT = YES ?
>> I admit that the config process is a bit painfull and stupid.
> Hm, I thought the POPPLER_0_23_OR_LATER=YES would deprecate the
> POPPLER_0_20_OR_LATER=YES so had this last one commented out.
> Declaring it seams to overcome these problems but I'm back to my old
> know one
> poppler.lib(GlobalParams.obj) : error LNK2005: _DllMain at 12 already
> defined in gdaldllmain.obj
> so I have to rebuild the poppler_GIT again
Just finish this issue. It works fine now. Thanks.
Joaquim
