[gdal-dev] Anyone tried using ogr2ogr on a remote MySQL db?
Jeff Lake admin at michiganwxsystem.com
Tue Jan 29 18:20:43 PST 2013
the remote host needs the permissions set properly for the ogr2ogr host
to connect to it
just using the proper user name/password most times is not enough ...
-Jeff Lake
MichiganWxSystem.com
AllisonHouse.com
TheWeatherCenter.net
GRLevelXStuff.com
On 1/29/2013 21:17, Muskie wrote:
> I can use ogrinfo and ogr2ogr fine on a local MySQL database...but not on a
> remote site. Can the problem be my provider? Has anyone had successfully
> connected via remote to upload data using ogr2ogr? If so, where was your
> site...what type of input did you use for 'host=' (IP?)?
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Anyone-tried-using-ogr2ogr-on-a-remote-MySQL-db-tp5030802.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
