[gdal-dev] GDAL WMS questions...
Wed Jan 30 12:50:19 PST 2013
Carl,
I'm afraid I'm not clear on the intricacies  here either.  I think the
CRS and SRS elements are to override how the request is sent to the
remote WMS server while the <Projection> element is how the projection
is described to GDAL (as returned by GDALDataset::GetProjectionRef()).
 I believe these are not always the same thing because some WMS
servers have peculiar ways of naming/describing projections that might
not jive with what GDAL normally understands.
I could also be off base with this assumption.
Best regards,
Frank
On Wed, Jan 30, 2013 at 12:35 PM, Carl Godkin <cgodkin at gmail.com> wrote:
> On Wed, Jan 30, 2013 at 12:19 PM, Travis Kirstine <traviskirstine at gmail.com>
> wrote:
>> My guess is that SRS is used when connecting to a WMS Version <= 1.1.1 and
>> CRS is used when connection to 1.3
> Thanks. I see that's in the docs.   But what is the difference between these
> two and <Projection> ?
> I'm new to this part of GDAL.  Thanks,
> carl
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
and watch the world go round - Rush    | Geospatial Software Developer
