[gdal-dev] Compile Gdal 1.9 with "WIN64=YES" setting
Livneh Yehiyam yehil at rafael.co.il
Thu Jan 31 04:38:11 PST 2013
Hi
>From the path of the VS compiler below, it seems that you are using the 32 bit compiler.
To compile for x64 you need to use the amd64 compiler.
Yehiyam
-----Original Message-----
From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of netcadturgay
Sent: Thursday, January 31, 2013 2:30 PM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] Compile Gdal 1.9 with "WIN64=YES" setting
I have build errors when I try to build to the Gdal 1.9 library for 64 bits.
How can I solve this problem? Or how can I build the gdal for 64 bits?
Thanks for your helps
Error:
   Creating library gdal_i.lib and object gdal_i.exp
LINK : error LNK2001: unresolved external symbol OGRFeatureStylePuller
LINK : error LNK2001: unresolved external symbol OSRValidate
LINK : error LNK2001: unresolved external symbol OPTGetProjectionMethods
LINK : error LNK2001: unresolved external symbol OGR_G_GetPointCount
LINK : error LNK2001: unresolved external symbol OGRRegisterAll
LINK : error LNK2001: unresolved external symbol GDALSimpleImageWarp
LINK : error LNK2001: unresolved external symbol GDALReprojectImage
LINK : error LNK2001: unresolved external symbol GDALComputeMedianCutPCT
LINK : error LNK2001: unresolved external symbol GDALDitherRGB2PCT
OCTNewCoordinateTransformation
gdal19.dll : fatal error LNK1120: 10 unresolved externals
NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
9.0\VC\BIN\link.EXE"' : return code '0x460'
Stop.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Compile-Gdal-1-9-with-WIN64-YES-setting-tp5031177.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
________________________________________
This message (including any attachments) issued by RAFAEL- ADVANCED DEFENSE SYSTEMS LTD. (hereinafter "RAFAEL") contains confidential information intended for a specific individual and purpose, may constitute information that is privileged or confidential or otherwise protected from disclosure. If you are not the intended recipient, you should contact us immediately and thereafter delete this message from your system. You are hereby notified that any disclosure, copying, dissemination, distribution or forwarding of this message, or the taking of any action based on it, is strictly prohibited. If you have received this e-mail in error, please notify us immediately by e-mail mailto:lawraf at rafael.co.il and completely delete or destroy any and all electronic or other copies of the original message and any attachments thereof.
