[gdal-dev] convert linestring to point data
Tyler Mitchell Tyler.Mitchell at actian.com
Thu Jan 31 07:45:13 PST 2013
Hi Murat,
I put together a PYthon script that uses OGR, just for you actually :)
https://github.com/spatialguru/NME/blob/master/ogr_explode.py
Run it like:
python ogr_explode.py e34c3_line.shp output.csv
It doesn't automatically create a shape file but you can convert from CSV to a shapefile with one more step.  But let me know first if this works for you.  Depending on how the Z or 3D dimension is stored, it may only have zeros in the third column of the CSV.  Try it and let me know!
Tyler
From: gdal-dev-bounces at lists.osgeo.org on behalf of Murat BEYHAN
Sent: Thu 1/31/2013 7:41 AM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] convert linestring to point data
Dear All,
I would like to convert linestring shape (.shp) file into point shape (.shp)
file using gdal. Is this made by gogr2ogr
ogr2ogr -f "ESRI Shapefile"  -nlt POINT e34c3_point.shp e34c3_line.shp
I have tried this but it gives an error
Please How can I do using command
I do this using qgis but I have to do using command.
Thanks
Murat
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130131/851f2b5b/attachment.html>
