[gdal-dev] dxf linewidth
Even Rouault even.rouault at mines-paris.org
Thu Jan 31 12:53:48 PST 2013
Le jeudi 31 janvier 2013 11:22:48, Marco Hugentobler a écrit :
> Hi Even
> Ok, done (http://trac.osgeo.org/gdal/ticket/4978).
> One thing that I did not do in the patch ( and should probably be done)
> is considering the symbology units. I saw that it is possible to query
> the unit type of the OGRStylePen. Is it possible to define e.g. the dpi
> in the featurestyle such that a driver might convert between pixel / mm?
I see that the DPI is st to a fixed value of 72 from what I see in
ogrfeaturestyle.cpp. Can't say anything on units in DXF.
